Help me choose
jhong200
53
My cpu is i5-4750
What do you recommend?? Performance per dollar??
Sapphire HD 7790 Dual-X OC Editition
Palit GTX 650 TI Boost 2GB OC Edition
OR
SAPPHIRE HD 7870 GHz Edition OC 2GB (optional)
inzone
Champion
The SAPPHIRE HD 7870 GHz Edition OC 2GB would be the best choice and give you the best performance, the other two are evenly matched and it would depend on which games you play and the supporting drivers for each that would determine the better card between those two.
If your budget allows the 7870 is the much higher performing card and it would allow you higher settings and resolutions.
Similar threads
