K Kun_ Reputable Apr 21, 2015 53 0 4,630 May 2, 2015 #1 [graphic card] which one is better for smother gaming? Msi n750 tf 2gd5 http://www.msi.com/product/vga/N750-TF-2GD5OC.html#hero-overview or Sapphire r7 260x 2gd5 http://www.sapphiretech.com/presentation/product/product_index.aspx?pid=2376&lid=1.
Solution WildCard999 May 2, 2015 I can't really explain in detail how it performs better but if you look at these benchmarks they will give you a good idea. http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_750_and_750_ti_review,17.html http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_750_and_750_ti_review,14.html 750ti>260X>750 The difference is only a few FPS (depending on game) but that can make a difference for a game to be playable or not.
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 May 2, 2015 #2 Go for the R7 260X, its faster. Source: http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html Upvote 0 Downvote
K Kun_ Reputable Apr 21, 2015 53 0 4,630 May 2, 2015 #3 WildCard999 : Go for the R7 260X, its faster. Source: http://www.tomshardware.com/reviews/gaming-graphics-card-review,3107-7.html can you explain at me more detail, why R7 260X is better than MSI N750 TF? Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 May 2, 2015 Solution #4 I can't really explain in detail how it performs better but if you look at these benchmarks they will give you a good idea. http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_750_and_750_ti_review,17.html http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_750_and_750_ti_review,14.html 750ti>260X>750 The difference is only a few FPS (depending on game) but that can make a difference for a game to be playable or not. Upvote 0 Downvote Solution
K Kun_ Reputable Apr 21, 2015 53 0 4,630 May 2, 2015 #5 WildCard999 : I can't really explain in detail how it performs better but if you look at these benchmarks they will give you a good idea. http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_750_and_750_ti_review,17.html http://www.guru3d.com/articles_pages/nvidia_geforce_gtx_750_and_750_ti_review,14.html 750ti>260X>750 The difference is only a few FPS (depending on game) but that can make a difference for a game to be playable or not. so MSI N750 tf 2GD5 is better than Sapphire R7 260X 2GD5? Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 May 2, 2015 #6 No since its only a GTX 750. The R7 260X is faster but if you went with the GTX 750ti then that would be faster out of the 3. Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 May 2, 2015 #7 The reason why I brought up the GTX 750ti is because the price is really close to the R7 260X. It will run cooler as well. Upvote 0 Downvote
K Kun_ Reputable Apr 21, 2015 53 0 4,630 May 2, 2015 #8 WildCard999 : The reason why I brought up the GTX 750ti is because the price is really close to the R7 260X. It will run cooler as well. okay, thank you for your opinion lad. Upvote 0 Downvote
