I have a $110 budget or 5,500 pesos budget.
You can surf here if you want to help find a better part: Dynaquestpc.com
So I need a PSU, Sata to USB cable and case fans (optional)
The PSU I had in mind was the Seasonic FOCUS+ 650W at 5,100 because I was thinking that 550W would not be enough in the future if I wanted to upgrade... Or should I get the 550W at 4,560. Or the M12ii EVO at 3,850?
The sata to usb cable is 350 pesos (fixed)
If possible, I also want to buy Tecware Orbis 3 pack at 1,550.
Help me pick the PSU.
SPECS:
I5 4570
12GB DDR3 1600MHZ
PALIT SUPER JETSTREAM GTX 1070
240GB SSD
1TB HDD
Phanteks P300
Thank you very much for those who want to help
SPECS:
I5 4570
12GB DDR3 1600MHZ
240GB SSD
1TB HDD
Phanteks P300
