Help me choose
dilrukrocks
Im getting 43C idle and above 72 on load on my E8400 E0 + stock cooler. my ambient is 32-35 @ daytime. I use Foxconn P45A-S with a case with good ventilation :( (2 front intake, 1 side intake, 2 back exhaust).
I really wanna get the temps down to get a good overclock. Will a Asus V-nardo do good? or will i have to go for a asus silent square or silnet knight 2? those are the only options where i live. If those wont do i will have to ask some friend to get one for me from Aus maybe.
So please help me out. My baby is really frying :sweat:
dilrukrocks
Are you sure the temps are ok for now? the temps wont rise even if i OC it to 3.6GHz on stock volts. so is it ok if i continue with that clock till i get a better cooler? :sarcastic:
Then how about Xigmatek HDT-D1284, Arctic Cooling Freezer 7 Pro or Cooler master Hyper 212 ? 45-50 AU$ is my budget.
Im from Sri lanka btw. its pretty hot here @ day time :??:
