Help me choosing ram modules for gaming pc
vitor_esilva1990
6
Hi!
I'm building a gaming pc and have been looking for reviews and youtube analysis for weeks, I'll buy the components in a week or two, right now my spec choices are:
Motherboard: Asus ROG Strix Z370-E Gaming
CPU: Intel Core i7-8700K prosessor
CPU Cooler: be quiet! Silent Loop 280 mm
RAM: *
GPU: Asus ROG Strix GeForce GTX 1080 Ti OC 11GB
SSD: Samsung 850 EVO 2,5" SSD 500 GB
PSU: EVGA Supernova G2 750W
Which one of these modules should i choose?
1. HyperX Fury Black DDR4 32GB (2x16GB) 2133Mhz
2. Corsair Vengeance DDR4 32 GB (2x16GB) 2133Mhz
3. Corsair Dominator Platinum DDR4 minne 32 GB (4x8GB) 2666Mhz
4. G.SKill Ripjaws V DDR4 RAM 32 GB (black) (2x16GB) 3200Mhz
5. G.SKill Trident Z RGB DDR4 RAM 32 GB (4x8GB) 3200Mhz
If you use that kind of ram :ouch: it seems the right choice to get 32gb.:)
I picked the G.Skill's first for the higher speed.The Corsair Dominators are good too,just lower speed. 😉 That's why i didn't even mention the 2133mhz sets.
I would go for 4-5-3 in that order. The Trident Z are probably the better compared to the Ripjaws V,but it is a 4 stick set that will give just abit more stress on the memory controller.It also likely will only show better performance under synthetic benchmarks,not gaming. Also it depends on the ram itself as wel,with that i mean what latencies/timings it works on.
You really want 32gb? Don't think for gaming you'll need that even soon,but it's up to you.If you're not going to upgrade the ram after this would the Trident Z maybe be the better choice.
So should go with the trident, can you tell me why picked them up instead of the corsairs? I see a lot of gaming builds in youtube and allmost all of them have the dominators or the vengeances, i was kinda surprised you picked up the tridents in first place...
Yeh i want to go with 32, I'm building this pc to play games but i also do a lot of stuff while i'm gaming and i have 16 already on my current build and sometimes it's almost not enough honestly lol
Ahahah I know it sounds crazy I'm aware of that, but yeh 32 it's the best option for me :)
Thank you for your advice :)
