Question Help me Complete a Build - Intel i7 + Nvidia 3070
Jun 18, 2022
11
I'm building a PC for a garage golf simulator (mainly to run FSX and GSPro software) and would love some help completing the puzzle on a few things. I have a Inten i7 CPU and Nvidia 3070 GPU on the way, but need to land everything else. Should I get an AIO for this build? Should I go DDR4 or DDR5 for Ram? Thoughts on other components? Thank you for your help!
geofelt
12700 or 12700K will require a lga1700 motherboard.
You will want a B660 or Z690 based motherboard.
If budget is an issue, B660 will be good.
The MATX boards are quite reasonable
Unless there is a big price difference, Z690 would be my choice.
They come in DDR4 and DDR5 variants.
Performance with DDR4 or DDR4 ram is comparable.
You can pick either.
I have no particular preference on brands.
DDR4 motherboards and ram are cheaper today.
A 2 x 8gb ram kit should be plenty, but many are going to 32gb since ram is not that expensive.
You have picked the two most important components, I think, well.
Look for a case to hold your parts. Pick one with looks you love.
It should have adequate front air intake capability to cool your parts.
I see no need for liquid cooling. A good twin tower air cooler will do the job equally well, be more reliable,quiet, and easier to install.
KyaraM
Notable
Mar 11, 2022
798
278
890
33
If you want a z690 board for your 12700k on a budget, I use that CPU on a MSI Pro Z690-A. There are four variants of the board, DDR4, DDR5, each with or without WiFi. They should all sit around the $200 mark. The one I have, for example, the DDR4 version without WiFi, only cost me 190€ and performs really well so far. Here is a VRM review of the board, it can essentially run any CPU without issues
And a general review of the board:
Jun 18, 2022
11
Awesome thank you. How do you feel about this motherboard?
https://www.newegg.com/p/N82E16813144487?Item=N82E16813144487&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afc-PCPartPicker&AFFID=2558510&AFFNAME=PCPartPicker&ACRID=1&ASID=https://pcpartpicker.com/&ranMID=44583&ranEAID=2558510&ranSiteID=8BacdVP0GFs-DIrMP5UyPOTQFtsAaD9R9w
Any specific cooling block you would recommend?
Jun 18, 2022
11
Thank you! Super helpful. What do you think of this board? https://www.newegg.com/p/N82E16813144487?Item=N82E16813144487&nm_mc=AFC-RAN-COM&cm_mmc=AFC-RAN-COM&utm_medium=affiliates&utm_source=afc-PCPartPicker&AFFID=2558510&AFFNAME=PCPartPicker&ACRID=1&ASID=https://pcpartpicker.com/&ranMID=44583&ranEAID=2558510&ranSiteID=8BacdVP0GFs-DIrMP5UyPOTQFtsAaD9R9w
Jun 18, 2022
11
or this one? https://www.newegg.com/p/N82E16813144512?Description=z690&cm_re=z690-_-13-144-512-_-Product&quicklink=true
geofelt
I like it.
Good vrm heatainks, two 8 pin eps connectors so power should never be an issue.
Looks like no RGB "bling" which is a plus for me.
As to coolers, that will depend some on the case and how high a air cooler it can support.
I would try to get a case with at least two front 140mm intakes or better.
It should have 160mm available for a good twin tower cooler.
I like the quality of the noctua coolers, but be quiet-DRP4, thermalright macho,
scythe fuma, Phanteks TC14 and others would do very well also.
Jun 18, 2022
11
I like it.
Appreciate you. Super helpful. You think either DDR4 or DDR5 route is neglible performance difference at this point?
