help me decide between amd64 and p4
brankulo
i am currently deciding between p4 3ghz northwood and amd athlon 64 3200+ newcastle processors. i am hard core gamer but study architecture as well. i want to play new games and also run acad, 3ds max and photoshop like apps. from what i read amd is better with games and p4 with 3d and acad apps. i cant decide because games and architecture are both my big hobbies. please help.
currently own:
amd athlon xp 2000+
gigabite mobo
512 mb ram
gigabite radeon 9800 pro
Cybercraig
2,058
The choice is clear: Northwood P4-3.0C!
Abit IS7 - 2.8C @ 3.5ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
Samsung 120gb ATA-100 - Maxtor 40gb ATA - 100
Sony DRU-510A - Yellowtail Merlot
darko21
1,098
Wrong get the amd athlon 64 3200+ it rocks!!!
If I glanced at a spilt box of tooth picks on the floor, could I tell you how many are in the pile. Not a chance, But then again I don't have to buy my underware at Kmart.
Schmide
1,442
I would look at <A HREF="http://forumz.tomshardware.com/hardware/modules.php?name=Forums&file=viewtopic&p=186763#186763" target="_new">this</A> before you decide.
Dichromatic for your viewing plesure...
darko21
1,098
all kiding aside get the amd quad pumped netburst way better preformer
Cybercraig
2,058
WARNING! WARNING! AN AN EXTREME EXTREME OVERCLOCKER OVERCLOCKER HAS HAS BREECHED BREECHED THE THE TIME/SPACE TIME/SPACE CONTINUUM CONTINUUM CAUSING CAUSING DOUBLE DOUBLE POSTS POSTS
Abit IS7 - 2.8C @ 3.4ghz - Mushkin PC4000 (2 X 512) - Sapphire 9800Pro - TT 420 watt Pure Power
BirdRobin
277
The space time continuum thing sound like it came from Back To The Future. (Michael J. Fox)
AMD A64 3200+ (2.2GHz Newcastle)
MSI K8N Neo Platinum
1GB Corsair DDR400 ValueSelect (CL2.5)
R9600Pro @ 500mhz Core, 340mhz Memory
darko21
1,098
All your base now are belong to us, make your time. HA HA HA.
darko21
1,098
But what if he wants to multi media encode and multi task at the same time also plans to use hyperthreaded proven and designed apps.
Cybercraig
2,058
Stick a top graphics card in that P4 rig and you'll play any game just fine. Stick some nice memory in the Newcastle rig and you can encode anything fast. You probably won't notice the difference between the two CPU's in everyday use. Six of one, a half dozen of the other. I would have to give a slight edge to the A64 in all around performance.
Galvin
107
I would go with 939. Amd don't phase out their chipsets every 6 months like intel does. So you'll have more longlevity.
I have intel, but they lagging behind amd in speed esspecially in games. So next system i'm building is the 939.
Coop
217
Socket 939 is here to stay a long time, you can easely upgrade in the future.
Also i think when Windows64 bit comes out in a few months you get a speed boost, you can not install windows64 on a P4(not yet)
Toms Hardware Site is a joke !
Looks like intel spent more on bribing reviewers to cover up it aint that great than they did in R&D, you know what im talking about Tom !
