[SOLVED] Help me decide between these 3 cases!
iSteven_6s
42
Deepcool Matrexx 55 white
Montech air 900 ARGB white
Montech Air 900 mesh white
CPU cooler: Scythe Fuma 2 (fans replaced with Corsair LL120s)
Motherboard: MSI X470 gaming plus
PSU: Bitfenix whisper M
GPU: RTX 2070 gigabyte windforce
RAM: trident Z RGB
Fans: 4 fans (no RGB)
Storage: some random NVMe drive
Ok I would pick the 900 Mesh.
But there are some things you could change if you want so it even looks better in my opinion:
Gpu: take the white variant, as it isnt that much more expensive than the standard version.
Motherboard: it has some red accents aswell as the red lighting. I would pick the msi x470 gaming plus MAX which is black/grey/white.
Hope it'll help you decide :)
Just by looking at them, I would pick the 900 Mesh. It looks really good and has decent airflow because of that mesh front.
Second place is the deepcool one just because it looks stunning with both glass on the side and at the front.
I will give you an update when you post your parts.
For an easier decision, please list your parts:
Motherboard
CPU cooler
PSU
GPU
RAM
Any fans?
Storage
It could really help chosing one that fits the most.
RAM: trident Z RGB
RAM: trident Z RGB
