Help me decide between these two processor/mobo combos
BrotherLaz
I'm building a new system, and I'm left with two possible options in terms of motherboard and processor (sadly, I can't choose much else, due to needing the price discount from a package deal).
Processor: Intel Conroe E6300 (1.86 Ghz)
Motherboard: 'Asrock Conroe Intel Chipset' <- ?? (Site lists Asrock 775Dual-VSTA, I think it's this one)
vs.
Processor: AMD X2 Dual Core 4200+
Motherboard: Asus M2N-E/Nforce 570
The rest of the build comprises: 2 GB of RAM (533 MHz 🙁 ), an 8800 GTS, pretty much interchangeable HDs, everything else is identical, and Vista.
Given these two options, which should I choose? The main issue is that I cannot replace or upgrade the processor without losing the package discount, so I have to choose one or the other.
I understand games don't stress the processor as much nowadays, but it shouldn't become a bottleneck either...
it would have been helpful to see the price on the combos
go with the conroe, save yourself a little cash and get a 7900gs instead of the 8x series and spend the savings on ddr2-800
Are they the same price? If so, the Conroe is better. But there wouldn't be a whole lot of difference.
Don't spend more on DDR2-800 for the Conroe, at stock speeds there is no difference between 800 and 533, and the 775Dual-VSTA is a shabby overclocker. Even DDR2 667 is faster than you'll ever get the 775Dual-VSTA to go.
