Help me decide: Sapphire r9 270x 4GB OC Crossfire
techincs132
5
Hi guys!
A month ago I bought this compurer:
-Sapphire Radeon R9 270X Dual-X with
Boost & OC, 4GB GDDR5
-AMD FX-6300 @4.3Ghz , cooler master 212evo
-Crucial Ballistix Sport 8GB DDR3 Kit
1600MHz
-ASUS M5A97 R2.0
Sockel AM3+ ATX
-WD Blue Desktop
WD10EZEX 1TB
-Crucial SSD MX100
256GB
-Corsair CX-Series CX500M 500 Watt
ATX 2.3
Atm, I get 45760 fps (somewhere around there) in BF4 all on ultra with Vsync nad AAx4. I have it OC'd at core: 1135 and memory:1500.
So now I want to upgrade to Crossfire the same graphic card. I know that I need better PSU, but I don't know if my CPU will bottleneck and if do I need more/better RAM? How much PSU (W) do you suggest?
Thanks for help :)
^ in theory yes - in real world no - in well optimised crossfire games you'll get a 60-70% performance boost.
These titles for a start
Farcry 4
Assassins creed unity
Dead rising 3
Have piss poor crossfire scaling - a 280x will perform better than crossfire in these cases (& many others)
You're looking at spending 280 euroes to get crossfire up & running.
If you buy this
http://www.computeruniverse.net/products/90569946/vertex3d-radeon-r9-280x-v2-uefi.asp
& sell your current card for say 120 euros your outlay is only 90 euros for a good 30-40% performance increase - it will run on your current PSU & makes a lot more sense to me.
If you're stable at 4.3ghz then I don't believe you would bottleneck with 270x crossfire personally.
However with having to replace the PSU to run cross fire I'd honestly look at selling your current card & getting a single 280x which will be fine on your current PSU.
Crossfire doesn't scale that well im any games - youd generally get only a slight increase over a 280x at the expense of huge power draw & having to purchase a new $$70 psu.
You can pick up a 280x for the same price as another 270x+PSU plus sell your current card for $90-$100 & you're better off IMO.
You asked if your cpu would bottle neck. I said more than likely. It means you may not get more fps than you already have because you cpu is being taxed already. It is a bit weak. get this psu. It is on sale with a $20.00 rebate. $39.00 for a high quality 750watt gold plus certified. Your ram is fine but don't think you will reap the benefits of crossfire unless you upgrade you cpu to a fx8350.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113284
http://www.newegg.com/Product/Product.aspx?Item=N82E16817182073
Farcry 4
Dead rising 3
If you buy this
