Help me decide: WD 320 or Seagate 500
TBirdOnline
24
Hi,
I have a 4yr old machine with an 80GB SATA drive. I have run out of space and need to upgrade. I am a gamer and not an audiophile. I am more interested in performance than I am in the amount of space. I am also price conscience and I would like to buy locally. My local Best Buy has the following two drives that fall in my price range (< $60):
Western Digital 320GB WD3200KSRTL
Warranty Terms - Parts3 year
Warranty Terms - Labor3 year
Product Height 1"
Product Width 4"
Product Weight 1.3 lbs.
Product Depth 5.8"
Drive Capacity 320GB
Drive Connectivity Serial ATA
Rotation Speed7200 rpm
Data Transfer Rate to/from InterfaceUp to 3 Gbps
Average Seek Time 8.9 ms
Cache Buffer Size 16MB
Average Latency 4.2 ms
Software Included Data Lifeguard Tools
OR
Seagate 500GB ST3500641AS-RK
Warranty Terms - Parts5 year
Warranty Terms - Labor5 year
Product Height 1"
Product Width 4"
Product Weight 1.6 lbs.
Product Depth 5.8"
Drive Capacity 500GB
Rotation Speed 7200 rpm
Average latency 4.16ms
Random read seek time <8.5ms
Software Included DiscWizard installation and SeaTools diagnostic
Outside of the size and the brand names, I am having trouble telling the differences. I can't seem to find any sites that review either of them. The Seagate has slightly lower user reviews, but more of them.
Any advice is much appreciated.
Thanks.
Tod
Do you have SATA I or II (1.5Gbps or 3.0 Gbps)?
Much debate has gone into WD vs. Seagate.
I like Seagate, and they have outperformed WD in some, if not most, benchmarks. Just look at the warranty difference, and avg. seek times/latency. Seagate wins.
You might try an online retailer! Microcenter or Newegg should beat Best Buy's prices. But then you have to wait for shipping. Wanting to stay local, try a local computer retailer.
AND make sure your motherboard supports 48-bit LBA, to use hard drives over 137GB in size. But most all motherboards built after January 2003 should support large HDD. Some require a BIOS update. But I think you are okay (e.g. 4 year old machine = 2006).
After looking, that Seagate drive is a 7200.9. They are now into 7200.12 (7200.09,.10,.11,.12).
That's why the price is low. The drive will work, just not at todays specs.
I paid $54.99 for a 500GB 7200.11 with 32MB cache at MicroCenter, but they are hard to find. 7200.12's only have 16MB cache, until you get over 1TB.
TBirdOnline
24
Well, I went ahead and picked up the Seagate. It may be older, but comparing the performance to my old drive (using PerformanceTest), it is a huge improvement. In some of the tests, I got a 70% increase in performance.
Thanks for the input.
