At first I was going to go for the Meshify C because of the front panel that's open for airflow and mainly for the small compact size but then the S340 has a closed panel which sucks and it also has a small form factor which is good and can support 3 HDD unlike the Meshify C which can only support 2. I could survive with 2 HDD but can my HX1000 psu that's 180mm fit into the Meshify C?
175mm is recommended by Fractal. I gotta get the RM650x that's 160mm if it's going to be a problem.
My V8 GTS cpu cooler can only enter in the Meshify C and I was thinking of selling it and getting an H100i V2 to fit in the S340 Elite if I choose to get the case. I'm using the 780Ti Matrix Platinum and the Maximus Formula VII so if the V8 GTS is going to be used in the Meshify C then my gpu can only fit into the second pcie slot unlike an AIO that I can just fit my gpu on the first pcie slot. So if I'm stil going to use my V8 GTS, it would have a big gap and look akward but I guess it's good for airflow?
Which case should I go with? Please help my troubled mind lol. Thanks.
