Help me decide which case
gamingforlife
13
Hello, I am trying to decide which case to get. I narrowed it down to two options. COUGAR Evolution:
http://www.cougar-world.com/products/pc_case/evolution.html
Cooler Master CM Storm Scout 2:
http://www.cmstorm.com/en/products/chassis/scout_2/.
The first one has fan control and hdd dock while the second one has a handle and more room for the graphics card (with the removal of the second cage). They are two awesome cases. I just cannot decide. I am going to install a SAPPHIRE Vapor-X R9 280x card. Will it fit on Cougar without being stuck. Also, can I install the same card in the CM one without removing the second cage. Need your feedback on this. Regards and thanks.
Yes you can install the Vapor-X without removing the cage in the CM. You'd actually have about 1/2 inch to spare. In the Cougar you'd have about 1 inch to spare. Either way the GPU will fit into either case without removing anything.
