This is my first build. I'll be using this machine for work and school. I'll need it to be able to run AutoCAD with no problems. I'll also need it to run some games for me on the side, such as Battlefield 4. I'm thinking it should be able to do those things no problem. I would just like to make sure that I haven't made in errors with my component selection.
Here's what I have so far:
Case Labs STH10 case
SeaSonic Platinum 1000W PSU
ASUS Sabertooth X79 MB
And here is what I plan on buying to finish this build:
Intel i7-3820 Quad Core
Corsair Vengeance 4x4GB DDR3 1600(to enable quad channel memory)
EVGA GeForce GTX 650 Ti Boost(I plan on getting 2)
Delta FFB1212EH-F00 120mm fans(1 intake, 1 exhaust)
Lamptron FC8 Fan Controller
Aside from a keyboard and mouse, I figure this is all I need to get it running. I can use my plasma TV as a monitor temporarily, but I would like to get a monitor as soon as possible after the components above are bought. I plan on running Windows 7. Do you guys notice any issues with anything I've listed above?
Thanks!
James
Thanks!
James
