[SOLVED] Help me find a monitor
PcBuilds3
28
Hey, I posted a question like this recently, but I found to to not really fit what I truly wanted.
Here's what I need.
24in
120-144hz(something my gtx 1060 can cap in)
1080p
G-Sync
Fast response time 1-5ms
Great colors and contrast.
Here's stuff I'd like but not needed
Speakers
Dp port
Non curved(a bit of curve is okay)
Some kind of warranty
I have about 400$ to spend on this montior, I'm willing to go a bit higher but 420$ is max.
Thank you for reading
WildCard999
Not really, that's the cheapest 1080P Gsync monitor I could find. I'm not sure why you wouldn't want it as it fits your needs and is within your budget. As for the refresh rate you can adjust it for your 1060 however it does have Gsync so even if the FPS fluctuates it will still appear smooth.
PcBuilds3
28
How about the Acer predator XB21H 24 in? Looks cheaper and it has speakers. Is there any reason I shouldn't buy that instead?
