Help me find best Graphics card
Decite
hi first of all thanks for looking im trying to find the best graphics card that will fit in my system that will run Battlefield 4 my current specs
Msi diamond p45
6gb corsair xms3 DHX
650w psu
AMD Radeon HD 5750 formula 1gb
any help is appreciated constructive criticism only
I checked out your motherboard, and I feel like if you get a good GPU the rest of your system is going to be slacking behind. You have old parts, and your mobo can only support core 2 duo chips. Seems like a good time to build a new one buddy.
been considering this :) thanks
Will be more cost effective in the future as well. You already need a new PSU, which means routing the power to all your components again, you might as well start new and build a current generation computer. You're just gonna be replacing part after part if you don't build a new one.
