help me find out what PC gaming case i have....
ok where do i get thermal paste and what kind and i want to get a liquid cooler for my cpu. and what gpu is good for my set up.
It should be close to the power supply at the bottom left corner. What the other guy was saying is that if you want to game on this pc, you will need a good GPU. A new cooler is good, but not essential. Thermal paste comes with the cooler. A budget GPU I'd recommend is the GTX 750Ti.
it isnt where you said. any where else i can look?
If it isn't there, the case doesn't have a model number. Your last option now is to look at the case manufacturers website and look for it. I can't see a brand on the case itself from the pictures. Did your grandfather get this pc prebuilt?
