[SOLVED] Help me finish my build!!
Mar 15, 2019
5
Hi there, I have bought a partly built PC from a friend and to finish it off i need a PSU, GPU and SSD. Can someone help advise which are good options? Budget £250-£300 but can go higher for something really good.
I was looking at second hand parts but have been told to stay away - is this the right thing to do?
I currently have:
Corsair Carbide Tower Case
Intel i5 4460 3.2GHz
Coolermaster masterliquid pro 280 64.21 CFM liquid CPU cooler
MSI Z97 PC Mate ATX Motherboard
Corsair Vengence pro 16gb (2 x 8 gb) DDR3-1600 RAM
All to power a 1080p Asus Monitor 144Hz
Have been looking at samsung SSD, a corsair 550w silver rated PCU and a GTX 1060 - but unsure on which exact models to get.
I will use it for gaming. I also would welcome any opinions on anything which i can change to greatly improve my PC. Thanks.
Something like this:
Storage: Crucial - MX500 500 GB 2.5" Solid State Drive (£61.75 @ Aria PC)
Video Card: MSI - GeForce GTX 1060 6GB 6 GB GT OCV1 Video Card (£184.98 @ Ebuyer)
Power Supply: SeaSonic - S12II 620 W 80+ Bronze Certified ATX Power Supply (£57.62 @ CCL Computers)
Total: £304.35
Generated by PCPartPicker 2019-03-15 12:56 GMT+0000
You can change MX500 to Samsung 860 Evo, but it adds cost (or you have to switch to lower capacity model to meet your budget).
Total: £304.35
Mar 15, 2019
5
Total: £304.35
Thank you, looks good, do you think my best way forward is to buy these parts new or can i get a higher spec if i go second hand?
