Question Help me finish my PC
Jun 16, 2019
I already have G1.Sniper 5 (Z87) + CPU i5 4670K + 16GB RAM but i just have HDR 4600
I think i will get 1060 6GB for my PC just play some games like: Apex Legends, LOL, CS:Go, GTA V. Do you think it compatible ??????
Yes, the GTX 1060 is compatible on your motherboard, as it is having 2 x PCI Express x16 slots, running at x16 for the GPU. But, do you also have a compatible Power supply unit for the card ? Update the system BIOS, before upgrading.
Compatible??? Yes.
Any discrete graphics card will be a big boost.
Here is a nice chart for sizing a PSU:
http://www.realhardtechx.com/index_archivos/Page362.htm
600w will run most any modern graphics card.
I have no problem overprovisioning a PSU a bit. Say 20%.
It will allow for a stronger future graphics card upgrade.
It will run cooler, quieter, and more efficiently in the middle third of it's range.
A PSU will only use the wattage demanded of it, regardless of it's max capability.
But a tier one or two PSU from a list such as this:
I would look for a Seasonic focus unit in 650 or 750w capacity.
https://www.newegg.com/seasonic-focus-plus-750-gold-ssr-750fx-750w/p/N82E16817151187
10 year warranty, and I particularly like the compact dimensions at 140mm deep.
