help me guys to choose options
Helmi_1
23
hey guys so im planning to upgrade my pc this month but im stuck on small budget 😀 so i have two options which are
1. GTX 980 and im gonna keep using my 8GB RAM
2. gtx 970 and i will buy 16 gb ram
please choose 1 and the reason !! thanks
so upgrading to 970 or 980 is jst wasting money in my opinion... like mike said next gen gpu and will come Q2... I would upgrade when ur falling below 30fps..
I Would Choose the GTX 980 because 8GB is still enough for 80% The games out there. You can later Easily add another 8GB inside ur PC. But the 980 ist More Powerfull compared to adding another 8GB Memorry with a 970. You will notice that alot more. Games like GTA 5 on Max settings and 1080P are consuming 7GB of RAM, i know it because i use this settings myself.
So my suggestion is to go with the GTX 980 and Later you can still add another 8GB RAM inside your pc and you will just be fine.
when will the pascal come anyway? and whats that ? sorry im new to pc stuff
