I am currently mining with MiningPoolHub and Awesome Minor utilizing the "Managed Profit Miner" setting. I have reduced the available algorithms for selection to: Equihash, Ethereum, Lyra2REv2, Lyra2z, and NeoScrypt (based on what I have seen people recommend but I will definitely take input on this as well). I just started today and so far have only seen it mine with Equihash where I am currently at 493 H/s average, which I think is pretty good based on my limited research. I am using a ASUS ROG Strix GTX 1070. I was getting less like 440ish until I applied my gaming overclock, but I am pretty sure overclocking for gaming and overclocking for mining are not the same. Can someone please tell me which sliders I should adjust and in what order/steps to improve my efficiency? I think the idea is to reduce GPU voltage and Power target while still maintaining the memory overclock? Max temp is 67*C with fans hitting 70% max btw. Here are pics of my current settings. THANKS!
Ok, i dont think my images are showing up so, using ASUS GPU Tweak:
GPU Boost Clock (MHz): +53, 1888 MHz
GPU Voltage (%): +100, 100%
Memory Clock (MHz): +900, 8908 MHz
Fan Speed (%): basically a custom curve that goes up to 70% for anything higher than 60*C
Power Target (%): +20, 120%
