Help me in building my first rig
praneeth1991
6
Im planning to upgrade my System with following config:
CPU: intel i5 4570 3.2 gz
Mobo: Gigabyte or Asus B85 chipset
Ram: 8Gb Corsair Vengeance 1600
GPU: XFX/Asus R9-270 OC edition
PSU: Cooler Master 500W
Case: Cooler Master Mid tower N 300
Hard Disk: 2TB WD 7200RPM
Will the config. work without any bottlenecks? plz help urgent
Everything looks like it will fit without any bottleneck, but i would suggest getting a larger power supply, especially if you plan to add another gpu or anything like that in the future.
Thanks for the reply but wont be upgrading it anymore:)
Hi praneeth1991
The build looks good. I would consider getting a Power Supply with more wattage and an SSD for a fast boot and fast computer and fast OS in general.
Hope this helped. 😀
