G
Guest
Guest
I need to overclock my 800Mhz tbird to 1Ghz!!(bridges are unlocked)
I use Asus A7V133 motherboard, latest BIOS.
320mb of CAS2 RAM (128Mb, 64mb of Kingmax RAM and 128Mb of CompUSA RAM).
my HSF is Global Win FOP38 (with a loud and FAST fan) connected directly to power supply cable (not to the motherboard!)
I use Arctic Silver2, and I applied the righ way! (followed al instructions)
my VCORE is 1.85
I tried to o'clock by setting multiplier of 10 and 100fsb, it would start and crash in a few seconds..(the temp. doesn't go highe than 48 I think...)
I tried 7.5 multiplier and 133fsb (RAM was set to 100Mhz ti make sure it's not memory problem)
wouldn't work either, crashes, but I believe the videocard and PCI devices handle it fine (GeFOrce2 MX AGP, USRobotics PCI modem and Sound Blaster Live! Value)
I tried setting memory to CAS3 - same thing...
What else can I try?
my VCORE is 1.85
