[SOLVED] Help me on my first pc build
Nov 26, 2019
5
Is this pc build good for gaming and doing my college project and surfing the web?
https://pcpartpicker.com/list/3yTC6R
Also i have some questions. The ram should i use the trident z rgb or trident z neo? And for a gtx 1660 ti should I get msi gaming x or asus rog strix gaming oc because the asus one is on sale at my country.
And also can you guys suggest any budget 24inch 144hz 1ms monitor.
Thanks in advanced
I personally would do something more along these lines.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($194.00 @ Amazon)
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.99 @ B&H)
Memory: Team T-Force Delta RGB 16 GB (2 x 8 GB) DDR4-3200 Memory ($59.99 @ Newegg)
Storage: Crucial BX500 480 GB 2.5" Solid State Drive ($54.95 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($82.99 @ Newegg)
Video Card: ASRock Radeon RX 5700 8 GB CHALLENGER D OC Video Card ($329.99 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case ($69.98 @ Amazon)
Power Supply: EVGA SuperNOVA G3 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($104.95 @ Walmart)
Total: $1011.84
Generated by PCPartPicker 2019-11-26 11:22 EST-0500
Having the dual SSD would be an improvement over the 1 HDD & 1 SSD. Here you install the OS and applications on the 480GB SSD and all games on the 1TB SSD. The RX5700 is a huge performance improvement, 20+%, from the GTX 1660Ti for only $20, or 7% more expensive. The Ryzen comes with a decent CPU cooler and you can use it first, just will be a little louder than the 212 EVO.
Total: $1011.84
Phaaze88
Dignified
Herald
Yeah, that's pretty good.
The Neo supposedly has better optimized timings for Ryzen cpus, but I doubt it beats the results of doing it yourself with Ryzen Dram Calculator... it just requires a little time on your end.
Up to you really. Go with the cheaper one. But if they happen to be the same price, then pick based on looks.
As for 2-fan vs 3-fan:
-generally, 3-fan should provide a little better cooling performance, but that's not until the higher rpm ranges - and that means a little more noise.
https://www.tomshardware.com/reviews/best-gaming-monitors,4533.html#section-best-budget-gaming-monitor
Nov 26, 2019
5
Total: $1011.84
Thanks for the suggestions, but i cant seem to find the ram and ssd in my country thou
Nov 26, 2019
5
Ok thankss
Nov 11, 2019
20
Thanks in advanced
If its a cheap gaming monitor you need check out the Acer KG241QF (KG241QP in my country) .It's a 23.6" 144Hz TN Panel monitor with 1ms response time and it supports freesync. If you can expand your budget and simply need your monitor to look cool and as bezelless as possible check out the Lenovo Y25F-10, which is a bit pricier than the Acer i mentioned.
Nov 26, 2019
5
Ok. Thanks for the suggest
