help me out
Feb 26, 2015
how do i connect corsair sp120 17 cpu fans ? can you tell me what are the cable management or splitter required i'm using corsair Ax 1200i and X99 asus rampage V extreme
If they are both being used on the same CPU cooler, you can connect them one of two ways:
Option 1: Connect one to the CPU_FAN header. Connect the other to the CPU_OPT header.
Option 2: Connect both to the CPU_FAN header using a simple 4-pin PWM splitter like this one:
http://www.amazon.com/gp/product/B002OFP6QW
Then run Fan Xpert from your ASUS AI Suite 3 software. Run the calibration program for all of your fans so the software knows exactly what fans you have. Then select the STANDARD fan profile for you CPU_FAN header (and CPU_OPT header...
Then run Fan Xpert from your ASUS AI Suite 3 software. Run the calibration program for all of your fans so the software knows exactly what fans you have. Then select the STANDARD fan profile for you CPU_FAN header (and CPU_OPT header if you use it.
Watch this video to understand the calibration. It tests to determine the exact max speed, minimum speed, and start-up speed for every fan in your system:
[video="http://www.youtube.com/watch?v=HFjQb0BdBiA"][/video]
