help me out ???
Vishakh_777
Commendable
Feb 15, 2016
i updated my windows 8.1 and now im not able to play fifa 14 again.... i dont have the cd version sooo can any1 help me out ?
When you say you updated your windows 8.1, do you mean you updated from an old version of windows (like 7 or vista) to windows 8.1, or did you install a windows update?
If you used the windows upgrade feature you should be able to find the old game files in a folder on the C: drive called Windows.old
Have you tried running the game in compatibility mode for Win 7/Vista/ XP versions? If not try that by enabling the compatibility mode from the properties of the Game's Exe.
If you have downloaded it via steam or Origin, contact tech support.
