So I am thinking about getting a GPU in 2 weeks or so and I am wondering if the prices will start going down a little bit. I was thinking about getting a 1050 or a 1060.
well its a question of budget... with your system and since the cards will not lower in price for at least 1-2 years I as see it. I would get a 1050ti or 1060 3gb or a 970/980ti used
Probably not in the next two weeks.
I wouldn't count on the next two months, either.
and your question is regarding what in specific?
and while your answering that question , can you care to fill us in what your make model of cpu, motherboard and power supply of your system ?
I am doing a Ryzen 1600 set up with a MSI Pro Carbon MOBO, Corsair 550W PSU, and 16 gb of Ripjaws V Series DDR4 - 2400 RAM. I basically want to know if getting a 1050 ti or a 1060 3gb would be a good choice or should I get a cheap one GPU for now until the prices are fixed.
