bycicle_repair_man;
His motherboard does support 125W CPUs, and it officially supports the FX-8320/50/70:
http://www.asus.com/Motherboards/M5A78LM_LX_PLUS/HelpDesk_CPU/
However C4nary:
- The VRMs on your motherboard are not cooled or heatsinked, which means overclocking is not recommended on this board. If you want to overclock, you have to either provide cooling for it, or replace the motherboard completely. The latter is recommended, since your power phase design is a mere 3+1 and any overclock will be unstable. I'm surprised the FX-8320 is even stable on stock speeds with that.
- Overclocking with stock coolers is not recommended. If you want to overclock, get at least a hyper evo 212 as CPU cooler. It's only $30.
- If you still...
