Help me! PC build turning off and on
MusleMan70
Commendable
Dec 6, 2016
Specs
Intel - Core i5-6500
MSI - H110M PRO-VD PLUS Micro ATX motherboard
G.Skill - Ripjaws V Series 8GB (2 x 4GB) DDR4-2800 Memory
SanDisk - SSD PLUS 120GB
Western Digital - Caviar Blue 1TB
Asus - GeForce GTX 1060 6GB
Deepcool - TESSERACT SW ATX Mid Tower Case
SeaSonic - 520W 80+ Bronze Certified Fully-Modular ATX Power Supply
TP-Link - TL-WN881ND PCI-Express x1 802.11b/g/n Wi-Fi Adapter
This happened today, when I woke up I went to turn my PC on then it powered up for split second then turned off then on for about 2 seconds then staying off, I had my iphone 5s charging on it all night so I think that might be it, it was in sleep mode when this happened, so I hit the kill switch on the PSU then turned it back on then I waited for about 30 mins then it turned on then when I put it in sleep mode it then turned on and off like the beginning of the story yeah thats it but, i don't what it was, I don't know if it was me charging my phone or something else can you people help me with this problem.
* This wont fix your problem
Well if this happens only when you are charging your phone , stop charging it 😛
I had some problems with "sleep mode" in the past ( black screens after it ) and i finally turned it off 😛
Since you have an ssd fast booting wont be a problem ( turn off sleep mode , and just turn your pc off when you dont use it)
or better waiting for a more experienced asnwer ;p ( maybe problem its with over-voltage or something)
