Question Help me pick a case plz
rhazta
39
Bought a graphics card from a friend turns out it’s too big for the case so need a new one, what’s a good case to fit all this in? Cheers
preferably from this local pc shop https://msy.com.au/without-psu
Mb M4a87td
X3 sata 3 harddrive 7200
Rx 580 Asus rog strix triple fans
Psu Corsair cx 550
Normal ssd
Any ATX Tower or ATX Mid-Tower should work. You just need to make sure the specs state it supports an ATX Form Factor motherboard.
-Wolf sends
Edit: My bad. I think I see the problem. The graphics card has a length of 298mm, You need to make sure the specs state a max graphics card length of 300mm or more.
Edit 2: On a budget, I'd probably look at this Antec VSK 4000B
