help me pick
Pvphater
6
Hello i'm wondering about several things i want to have a 1080p gaming PC but i don't know what Motherboard, Ram and Graffics card to pick and affcourse the CPU major thing what will be a good choice ??
I'm thinking about Intel Core I5 6600 for a CPU for RAM may 2 stix of 4gigs DDR4 in dual channle on 2400Mhr but for the motherboard and the graffics don't got an idea have read that Z270 are good but what vendor give me some advices pls
If you can tell us what budget you have, and where you are, our member should find those for you. Like fill out this form. http://www.tomshardware.com/forum/353572-31-build-upgrade-advice
But first, you may consider to buy the amd ryzen 1500x or 7th gen i5, next if you buy the non-K version intel i5 may consider to buy the H170 for the 6th gen, H270, even the b250 for the 7th cpu.
Here is one review for ryzen cpu, intel i5. http://www.techspot.com/review/1379-and-ryzen-5-1600x-1500x/
i had an old old rig right now and was thinking to keep my 22" Philips monetor and hes working on 1680-1050 60Hz and i can't deliver to my self the experiense i was i had an Asus Pq5 se plus mother board and Intel dual core E8400( aka wolfdale) on 3.0GHz 2x2Gigs of DDR 2 AData 1006Mhz and some sort of don't remembet what PSU 650W 1x HDD WD 1T no ssds and ya thats most
For AMD PC something like:
CPU: AMD - Ryzen 5 1500X 3.5GHz Quad-Core Processor (£174.49 @ CCL Computers)
Motherboard: Asus - PRIME B350M-A Micro ATX AM4 Motherboard (£68.52 @ Amazon UK)
Memory: Kingston - HyperX Fury Black 8GB (2 x 4GB) DDR4-2133 Memory (£55.95 @ Amazon UK)
Video Card: EVGA - GeForce GTX 1060 6GB 6GB SC GAMING Video Card (£214.97 @ CCL Computers)
Total: £513.93
Generated by PCPartPicker 2017-05-12 19:56 BST+0100
For intel system:
CPU: Intel - Core i5-7500 3.4GHz Quad-Core Processor (£175.00 @ Aria PC)
Motherboard: Gigabyte - GA-B250M-DS3H Micro ATX LGA1151 Motherboard (£65.41 @ CCL Computers)
Memory: ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2800 Memory (£50.63 @ Amazon UK)
Video Card: MSI - Radeon RX 580 8GB ARMOR OC Video Card (£228.04 @ More Computers)
Total: £519.08
Either rx580 or gtx1060 will be the best gpu for games in 1080p or less. So check out which games you play most, and pick the re580 or gtx1060, you should but the PSU for the new PC, if your PSU is old than 5yr.
Review: http://www.techspot.com/review/1393-radeon-rx-580-vs-geforce-gtx-1060/
