Help me please with my 9800 and cat4.4s
G
Guest
Guest
Archived from groups: alt.comp.periphs.videocards.ati (More info?)
He me please with my fully functioning ATI Radeon 9800 Pro (256meg) video
card and Catalyst 4.4 drivers.
No matter what I do the Cards and installed drivers just keep functioning
correctly without a mishap what-so-ever!!
Is there something I'm not doing to get all these problems you guys are
having? I'm feeling so left out of the loop here !!
P.S. This post simply unserious. *cheers* and hope some of the ppl video
problems get solved here...
Yes, I can help, please follow these steps:
1) Download as many "dubious" speed hack programs for your PC as you can
find, no matter what their source or what your Anti-virus software tells
you.
2) Swap backwards and forwards from Nvidia to ATi graphics cards several
times without fulling uninstalling the previous drivers, and if you can find
one you could try a Matrox card too.
3) Hack your registry, just for the fun of it, without any ideas what you
are doing.
4) Delete all those unnecessary files in your c:\Windows directory.
5) Go into your bios and raise the CPU and RAM speeds as high as they'll go,
after all the motherboard manufacturers wouldnt put those setting there if
they were'nt safe, would they.
Finally, clear a path from your PC to the nearest exit, and i suggest using
a ling thin stick to turn your PC on from a distance, and be prepared to run
away at speed as your PC goes up in smoke. If you are still unhappy with
the results at this stage you can also try altering the voltage selector on
your PSU (if it has one) to the incorrect voltage for your area.
CrimsonLiar
"RipFlex" <dbossom1@cogeco.ca> wrote in message
news:zzFic.1427$_12.1268@read1.cgocable.net...
Geeez, thanks, I certainly try them suggestions!!
I ARE NOT NORMAL !
"CrimsonLiar" <trash@trash.com> wrote in message
news:yPKic.18$Od6.11@newsfe5-gui.server.ntli.net...
> you.
find
> are doing.
go,
using
run
on
> CrimsonLiar
video
functioning
<snip>
I've got the same damn problem. ;-)
I thought *I* was the only one with that pesky reliable quality bug.
No matter how many times I load new "Cat" drivers over old ones, the darn
thing just keeps working.
Doesnt Far Cry just look fantastic. My gawd, the physics and graphics of
that game are intense.
"dorkus.erectus" <nhdgef@whoever.org> wrote in message
news:zhVic.12600$kk7.1302@twister.rdc-kc.rr.com...
video
functioning
> <snip>
No, me too.
It's quiet... a little too quiet 😛
Looks amazing, I recently managed to obtain the e3 techdemo of half life2,
both very impressive.
Ben
A7N8X FAQ: www.ben.pope.name/a7n8x_faq.html
Questions by email will likely be ignored, please use the newsgroups.
I'm not just a number. To many, I'm known as a String...
