Hi everyone,
a few days ago I decided I wanted to build myself a mighty gaming PC, I am only a student so my budget is pretty tight and is about £460-£560 (and if your wondering why 60 it is because I have a £60 gift voucher to amazon so really my budget is £400-£500 and also the £60 voucher). I have managed to stay within that limit but need your help guys to see if I can improve anything with it. My build is as follows:
Intel Core i5 2500K - 161.13 - 60 voucher= £101.13
http://www.amazon.co.uk/-/dp/B004FA8NX2?tag=invihand-21
Biostar TP67B+ B3 Revision P67 Socket 1155 5.1 Channel Audio ATX Motherboard - £86.02
http://www.ebuyer.com/255159-biostar-tp67b-b3-revision-p67-socket-1155-5-1-channel-audio-atx-motherboard-tp67b-
G-Skill 8GB (2x4GB) DDR3 1600Mhz RipjawsX Memory Kit CL9 (9-9-9-24) 1.5V - £40.98
http://www.ebuyer.com/264750-g-skill-8gb-2x4gb-ddr3-1600mhz-ripjawsx-memory-kit-cl9-9-9-9-24-1-5v-f3-12800cl9d-8gbxl
Seagate 1TB 3.5" Barracuda SATA-III 6Gb/s Hard Drive - 7200RPM 32MB Cache - £45.11
http://www.ebuyer.com/252858-seagate-1tb-3-5-barracuda-sata-iii-6gb-s-hard-drive-7200rpm-32mb-cache-st31000524as
LiteOn iHAS124-19 24x DVD±RW DL & RAM SATA Optical Drive - OEM Black with Nero Essentials - £13.98
http://www.ebuyer.com/176026-liteon-ihas124-19-24x-dvd-rw-dl-ram-sata-optical-drive-oem-ihas124-19
XFX HD 6870 900MHz 1GB GDDR5 Dual DVI Dual DisplayPort HDMI PCI-E Graphics Card - £139
http://www.ebuyer.com/279585-xfx-hd-6870-900mhz-1gb-gddr5-dual-dvi-dual-displayport-hdmi-pci-e-hd-687a-zhfc
With the power supply I am not sure, how about this one:
Corsair Memory 600W Builder Series CX V2 ATX PSU - £49.99
http://www.dabs.com/products/corsair-memory-600w-builder-series-cx-v2-atx-psu-7JSQ.html?utm_source=google&utm_medium=product+search&utm_content=Q200
and the case will be about £25, haven't found a good one yet, any suggestions
total- £501.21
I will be OCing the 2500k to the maximum stable speed i can get (or trying to anyway as i have never done any overclocking before). I may decide to do some crossfire later on (how much more would this improve performance, is it worth buying the second graphics card?) when I save up a bit more money and also possibly get a small SSD hard drive and maybe a blu-ray drive.
So what do you guys think, any changes, or improvements you might have would be highly appreciated 😀 .
total- £501.21
