help me please.
doorlessjam
13
hey. guys would just like to ask if i put a Asus AMD Radeon R9 270X DirectCU II Top 4GB GDDR5 Graphics Card, in my computer, would it run perfectly, and not effect anything in my computer,
i have a gigabyte ga-z87-hd3 motherboard
8Gb ram
AMD A-10 6800K APU 4.10Ghz
fans, cpu cooler,
You motherboard and psu seem more then suffcient. What cpu do you have? Not that your that the cpu would cause any any issues, but if it's on the lower end it could be a limiting factor on the gpu. Everything will work just fine, but it would just be a limiting factor.
Also i have a AMD Radeon R7 260 1GB Graphics Card, in my computer atm, that's why i wanted to upgrade it, but i wouldn't be able to put 2 of them in would i? cause they are r7 and r9?
It would work in your PC fine one note thought the new one would take 2x6 pin connectors. so you would need 3x6 pin connectors for both and you probably don't need it with your new card.
okay thank's its just cause, i bought 3x monitors, and going for the eyefinity wanted a decent enough graphic's card to contain it, u think that's decent enough just that 1 graphic's card r9?
i bought a StarTech DisplayPort to VGA Video Adapter Converter, and 3x Asus VN247H 23.6-inch Widescreen LED Multimedia Monitor (1920x1080, 1ms, 2x HDMI, VGA, Full HD 1080p, Super Narrow Frame)
Latest posts
