H huss4in Reputable Feb 28, 2015 18 0 4,510 Mar 23, 2015 #1 what is the best Asus motherboard take in mind it should be $150-180
kanewolf Titan Moderator May 29, 2013 38,669 3,813 156,790 Mar 23, 2015 #2 That is not a question anybody can answer. You will need to identify what CPU you need to support. Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Mar 23, 2015 #3 as said, what CPU are you using and which dimension should it be to fit into your unknown case. mATX, ATX,.... Upvote 0 Downvote
H huss4in Reputable Feb 28, 2015 18 0 4,510 Mar 24, 2015 #4 kanewolf : That is not a question anybody can answer. You will need to identify what CPU you need to support. LGA 1150 socket type Upvote 0 Downvote
helpstar Titan Dec 25, 2012 14,854 1,110 84,840 Mar 24, 2015 #6 http://pcpartpicker.com/part/asus-motherboard-z97pro has two more sata ports, flashback button, better audio, but can just quad sli and 3way crossfire compared to z97-a (4-way crossfire) Upvote 0 Downvote
Sweeds Reputable Mar 24, 2015 132 0 4,690 Mar 24, 2015 #7 huss4in : what is the best Asus motherboard take in mind it should be $150-180 Asus z97-A $150 Asus Z97I-PLUS $160 Asus SABERTOOTH Z97 MARK2 $180 all great boards, my personal favorite is the sabertooth Upvote 0 Downvote
