M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #1 Im in the middle of building a pc and I thought everything was all good then I turned it on the fans and lights went on but nothing on my monitor?
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #2 what do you mean by in the middle? until you get so far you wont get any display Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #3 Everything is in I just dont know if its all plugged in correctly im pretty sure it is but what would be causing this? Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #4 could be a few things did you plug in the 4/8 pin power Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #5 Ive plugged in everything that I could but im not sure if its 100% correct Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #6 the 4/8 pin is usually up around the top left corner of the motherboard looking at the board once its installed somewhere close to the cpu Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #7 Ok no its not will that be the cable called cpu? Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #8 yes it probably will be labelled cpu Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #9 Ok it powered on then went off again then booted up again, normal? Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #10 yes it can do a double post do you have display now? Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #11 No still no display any other ideas? Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #12 are you using a graphics card or just integrated graphics? Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #13 Im using a graphics card Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #14 make sure any 6 pin or 8 pin connectors are connected to the graphics card make sure your monitor is connected to the graphics card not integrated graphics Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #15 Ok that worked but it said cpu fan error so I shut it down what could be wrong? Upvote 0 Downvote
Lee-m Distinguished Jan 27, 2009 866 0 19,210 Jul 23, 2015 #16 A system spec would be handy, then people would know what needs power and what doesnt. Make sure the system speaker is plugged in to listen for any beeps (motherboards still do that right?), some have an onboard LED error number you should look for. Upvote 0 Downvote
G Guest Guest Jul 23, 2015 #17 Do you have a heatsink and fan attached to the CPU? Make sure you connect the power from that fan into the header on the motherboard labeled CPU fan Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #18 Asus maximus ranger, gtx 980ti, x61, 16gb ripjawsx, h440, samsung 256gb ssd, wd black 2T, ax760i, i7 4790k Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #19 MattEC : Ok that worked but it said cpu fan error so I shut it down what could be wrong? connect the cpu fan to the cpu fan header Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #21 The number that comes up is a2 and it says here ide detect? What does that mean Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #22 MattEC : It is definitely to the cpu and not cpu opt? (optional) Upvote 0 Downvote
mcnumpty23 Polypheme Jul 15, 2011 15,518 0 66,960 Jul 23, 2015 #24 does the pump connector on that look the same as the fan connector? if so you may have connected the pump to the cpu header instead of the fan Upvote 0 Downvote
M MattEC Reputable Mar 7, 2015 28 0 4,530 Jul 23, 2015 #25 Would you be able to help me tomorow I have work in the morning and its real late ? Upvote 0 Downvote
