Help me please
Jessse
5
I have a dell Optiplex 760 and I want to play minecraft but Ineed a graphics card And I dont know Witch one to get help me
Hi! Jessse so there is 1 factor I need to know then I can help you out, so is your case on the bigger side real bulky? Or is your case slim and skinny because some graphics cards might not fit if I choose one for you. So reply to me on this. Also from what I'm seeing it looks like you might need a new power supply. But then you may need to get a new case unless you want to kind of home make a piece of sheet metal and screw it on there, as the power supply you would be getting wouldn't format correctly as your PC is generic pre built. There might be graphics cards that might not need a new power supply but my guess is it will. So if you recased your current motherboard might not fit as you have a generic motherboard that is custom made by DELL. So I recommend you try and find a power supply, new case that fits (thats universal with motherboard and other parts), and then get to your graphics card. Unless your case is big and supports standard sized power supplys your best bet is to start off with a new case.
The GT1030 only draws about 35w and its low profile so it should work. It does require a digital monitor is the only possible issue. If you have the slimest version of the 760 You may have to buy a smaller bracket or mode the one with the card.
I absolutely agree with the GT 1030, as it is a single slot graphics card, which should fit just fine in your Optiplex chassis. Basically any GT card from NVIDIA from the last 3 years should work just fine for playing a game such as Minecraft, but the 1030 will give you very reasonable frame rates.
