WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jan 28, 2019 #2 Yes it would work on that motherboard as it supports M.2. Upvote 0 Downvote
R reservating1 Dec 8, 2018 22 0 10 Jan 28, 2019 #3 I should put it under the pcie slot right Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jan 28, 2019 #4 reservating1 : I should put it under the pcie slot right It connects on the M.2 slot between the top PCIE slot and CPU socket. Upvote 0 Downvote
R reservating1 Dec 8, 2018 22 0 10 Jan 28, 2019 #5 What about the slot under Asus logo Where u need to open the screw Upvote 0 Downvote
WildCard999 Titan Moderator Jul 18, 2014 21,784 1,935 93,640 Jan 28, 2019 #6 reservating1 : What about the slot under Asus logo Where u need to open the screw Either spot is fine. Upvote 0 Downvote
