A anubhavkapil77777 Reputable Oct 9, 2014 16 0 4,510 Oct 9, 2014 #1 hey guys I am going to upgrade my motherboard from DG31GL to Gigabyte ga g41 combo. does it support 2 gb ram ddr2 and ati radeon hd 5570,6670,5450,5670 and will it fit in my cpu Intel Core 2 @ 2.80GHz 45nm Technology
Solution L L lightcloud Oct 9, 2014 If the RAM ahead DDR2 RAM slots then you had be fine. If the motherboard has a free PCI Express port, then a graphics card can be installed. You will require the same socket— LGA775. Which both has so it will fit.
L lightcloud Judicious Jul 20, 2014 5,204 0 32,960 Oct 9, 2014 Solution #2 If the RAM ahead DDR2 RAM slots then you had be fine. If the motherboard has a free PCI Express port, then a graphics card can be installed. You will require the same socket— LGA775. Which both has so it will fit. Upvote 0 Downvote Solution
Novuake Champion Aug 27, 2011 14,302 0 56,960 Oct 9, 2014 #3 Please... Stop... Spamming... http://www.tomshardware.com/answers/id-2328566/question.html http://www.tomshardware.com/answers/id-2328578/rock-mob.html Upvote 0 Downvote
