Question Help me pls! My pc is flickering blackscreen with white lines
Jun 2, 2019
4
Help me pls! My pc is flickering blackscreen with white lines.
I dont know the cause of this. My gpu is Rx 570.
Sometimes it flickers while browsing and editing but never flicker while playing heavy games.
Pls help me.
Can you provide FULL PC specs, and more details about your system and the current issue at hand ?
. "Complete" system specs should ALWAYS be accompanied with any driver, hardware, or performance question. Do not post DXDiag reports as they contain a TON of useless information.
Please supply the following system details/information:
(Complete System Specs)
-CPU make and model# (clock speed/voltage, type of cooler, and "Core" temperature @ idle and load)
-Motherboard make & model# (include Bios version if graphics card is not recognized or you are having stability issues)
-RAM (amount, clock speed, model#/link of kit, configuration)
-Graphics card(s) make and model# (clock speed, voltage if modified, Driver version and GPU temp both @ idle and load)
-Power supply make,model#, "AND" age (note if using 110V or 220V A/C input)
-HDD/SSD configuration (ie: Raid setup/ back up/ OS drive/etc..)
-Case/Chasis make,model# (fan make, model#, and configuration if having thermal issues)
-Operating System (If using Windows note Framework and service pack version)
-Monitor make, model#, and resolution (If model# is unknown list resolution and refresh rate)
*If the unit is a "laptop" or "All-in-one" system you must note the make and model# of the unit. Be sure you are ALWAYS using the OEM/manufacturer's Driver updates for the unit.
*If "Crashing":
-Note the nature of the "crash" in detail, as there are several definitions for the word "crash".
*If "performance" related issue:
-Note the "exact" point in which the performance reduction occurred (ie: After Windows update, After Bios update, After Driver update, After thermal system shutdown, After Hardware change/upgrade etc...)
*For diagnostic purposes please disable the following:
-Any/all Antivirus/ Anti-malware software
-Any/all OSD monitoring software
-ALL overclocks outside of factory spec
Reactions: roncruz
Jun 2, 2019
4
Im sorry for the super late reply
My specs:
Cpu : Ryzen 3 2200g
Gpu : Aorus Rx570
Motherboard : Asus EX-A320M-GAMING
Ram : Ballistix Tactical 4x2gb
Power supply : Corsair Vs450 (450watts)
