Help me reduce price on first build
TheTheory
102
I need the price to be around $850
Here is what I had but it is over my price range.. I want to keep performance as much as possible!
The main use of this system will be WoW and Streaming Console CoD.
Also I want to only use Newegg so I can get it all shipped together quickly, thanks!
http://pcpartpicker.com/p/1WIca
CPU: Intel Core i5-4570 3.2GHz Quad-Core Processor ($189.99 @ Newegg)
Motherboard: ASRock H87M Micro ATX LGA1150 Motherboard ($87.55 @ Newegg)
Memory: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-1866 Memory ($68.00 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.99 @ Newegg)
Video Card: EVGA GeForce GTX 760 2GB Video Card ($254.99 @ Newegg)
Case: Apevia X-DREAMER4-GN ATX Mid Tower Case ($72.98 @ Newegg)
Power Supply: XFX 550W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply ($65.98 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($16.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($99.99 @ Newegg)
Total: $926.46
(Generated by PCPartPicker 2013-11-03 03:49 EST-0500)
Massive downgrade on the GPU, but there isn't much else you can really do when your $75 over on a budget build.
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory ($72.00 @ Newegg)
Video Card: MSI GeForce GTX 660 2GB Video Card ($169.99 @ Newegg)
Case: Corsair 350D MicroATX Mid Tower Case ($69.99 @ Newegg)...
Youre really going to run that on a 550 XFX bronze PSU? I know it goes completely against what question youre asking, but you should save more, and try not to cut corners, if youre looking at getting a PC you dont need to upgrade later.
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer ($14.99 @ Newegg)
Total: $840.47
(Generated by PCPartPicker 2013-11-03 04:14 EST-0500)
You could drop the Optical Drive altogether, pull one out of an old machine if you have one.
theres not a lot you can save, maybe 10 bux here and there with about 40 in total... pick similar parts with rebates or combo deals is pretty much the only way your gonna drop the price significantly... its a damn nice rig for the money thats for sure.
but check out the fractal design cases. there pretty decent for people on a budget.
antec do a better 550w psu that costs about 10 bux cheaper and crucial do cheaper 8 gig ram bundles on the balistix line.
