When starting, the motherboard gives me a beep code (continuous short beeps) the motherboard is a gigabyte GA-z77-HD3. Apparently that beep code means memory not correctly installed. I've even swapped out ram that I know that works but still the same problem. After the beep code, the computer restarts and reboots. I originally thought it was the power supply because I had problems with that before. I just noticed when starting, the cpu fans spins for a bit then stops. The other fans keep going until it restarts. Do you think it's the psu or something else? I could buy a cheap 500w power supply for £35 to see if it works but didn't want to buy it if there's something else I can try first.
