Here is my current Hardware:
Abit KN9-Ultra Mobo, Tuniq Tower 120, AMD X2 6000+, 2x2GB G.Skill DDR2800 RAM, 74 GB Raptor 10kRPM, 2 x 500 WD 7200 RPM HD's, 2 x WD 640GB 2700. HD's, ASUS EAH4870 Vid Card, PC Power & Cooling 750w PSU, Sunbeam Transformer Case w/ 3 x 80mm 1 x 120mm Fans, Windows 7 RC1 x64. Windows Index Rating 5.9 (determined by lowest score which oddly is the Hard Drive. Makes no sense using a 10k RPM drive with over 80% free, I digress)
Available Hardware:
Gigabyte GA-Ma78GM-US2H Mobo, 2x2GB G.Skill DDR2 1066 Ram, AMD Phenom 9850 BE, Chieftec Case w/ plenty of fans, more drives, etc.
Here is what I did before:
I built the AMD Phenom with the Gigabyte Mobo but it was idling really hot and hit over 62c on load. I used a Xigmatek Rifle Cooler with it and now that is gone. The only thing I didn't try was the Tuniq Tower on that build. The Gigabyte Mobo is a micro and has the ram slots pretty close to the CPU Socket and also the NorthBridge is directly over where the PCI x sits. The Asus card I have puts out some serious heat since it's already overclocked from ASUS and I don't want it to add to the heating issue.
What I am looking for/purpose of this post:
Based on the hardware that I have, I would like to know if anyone has used similar hardware and was able to keep the AMD Phenom relatively cool? I don't want to tear these down and do it for nothing (again). The other obvious option is to water cool it but if I chose that route, I would get a new, deeper case. So, with what I have, what would you do?
Thanks in advance.
Available Hardware:
Thanks in advance.
