i changed that in the update list.
I don't think I'm likely to overclock as I worry about overstressing things (I don't like forking out money, probably the reason why I'm still using a p4 1.4 with 384mb ram and a 32meg geforce2)
what about the graphics card? anything cheaper I can get that will perform as well as the xtx?
I have 2 more questions....
Would I be better off buying a single stick of 1GB ram instead of a matched pair of 512 seeing as I'll probably eventually upgrade to 2gb anyway...can I do that as I know with my rdram you have to have pairs???
what's the benefit of a matched pair anyway?
and finally....I have a pci firewire card so would i be able to rig something up internally to connect this to the front firewire port that this case has? at least I think it has anyway!
Dual-channel architecture DDR SDRAM describes a motherboard technology that effectively doubles data throughput in the frontside bus from RAM to the memory controller. Dual Channel-enabled memory controllers utilize two 64-bit data channels, resulting in a total bandwidth of 128 bits, to move data from RAM to the CPU.
In order to achieve this, the DDR SDRAM memory modules must be installed into matching memory slots, which are usually color coded on the motherboard. Each memory module in each slot should be identical to the one in its matching slot. It's also possible to use similar memory sticks from different manufacturers or different production series as long they are of the same size, specification, the same number of memory chips and internal organization.
Ummm...11C is not possible unless your CPU is in the freezer......CPU 11C
System 33C
PWM 33C
are they ok?
Yeah, I think the thermometer on your mobo is screwed up for the cpu. Because 20 C is room temp and 11 C is 58 F. So, yeah, your thermometer is screwed.
DDay
