Updated thread, please jump to last post:
http://www.tomshardware.co.uk/forum/id-3542892/choose-monitor-understand.html#20530885
Original post:
Original post:
Hello all,
My old LG W2261v died.
Main use is games and budget arround 250€ or less (old LG were 180€). Can be more if worthy.
With my specs (at bottom) i cannot get a decent performance on 1440p resolution, but i would like something for the future.
Still i think 1080p monitors would be enough.
I think i will upgrade to a NVIDIA card but G-sync monitors are too expensive and not sure if i need it.
I don't want speakers.
22" was not bad.
Doubts:
Monitors (starting point; pretty sure i'll end up with something totally different, not even what you suggest xD , but you'll help me anyway 😉 ):
Hope you can help me to get a better idea of what do i need for me, to start to search it. Any help-suggestion is welcome 😉 .
Thank you very much in advance
My specs:
22" was not bad.
Doubts:
1- Playing on a 1440p monitor at 1080p would look like like playing on a 1080p monitor at 900p or 720p?, i mean, big pixels and a bit blurrier? (i think it should look like 1080p on 1080p but seems it does not work like that).
1b- Maybe it is better supersampling than more resolution? But I tried supersampling on some games and i didn't like it, and to have "same feeling" on 1440p than on 1080p (on native res), i think is not worth it (?? 😛).
2- Are 144hz screens worth it even if, by now, i won't be close to get those FPS? (maybe i could on some but in others not even 30fps xD ). Some say that playing on games that cannot reach 144hz feel pretty bad once you have played at 144hz; so if, by now (maybe in future), i cannot be able to reach a lot on some games, not sure if would be worse than a 60hz screen.
3- I have been looking for some of the most "popular" monitors and i have seen most of them have TN panels. I like the best colours i can get but i usually get motion sickness on games so maybe better refresh rates are better for me than better IPS colours?
1- iiyama G-MASTER GB2488HSU-B3 303€: i feel a bit attracted to this, don't know why as it is a bit expensive, has speakers and freesync.
2- Benq monitors (looking at this web i have seen a lot of pro players with Benq monitors, not sure if marketing / and no, no plans to be a pro player xD):
2a- BenQ ZOWIE XL2411 259€
2b- BenQ XL2411Z (unavailable, was 2nd hand for 200€)
3- Samsung C24FG70FQU 284€: Curved, not sure for nongaming stuff.
4- AOC G2460PF 254€
5- ASUS VG248QE 259€
6- Acer Predator GN246HLB 240€
7- HP OMEN 25 254€
8- LG 24GM79G-B 300€
9- DELL S Series S2418H 210€ HDR Monitor (not sure if real or worth it as the first iiyama seems to have 8-bit colours and this has 6/ a bit confused)
10- BenQ Monitor EW277HDR 247€ HDR Monitor (not sure if real or worth it)
11- iiyama ProLite XUB2492HSU-B1 202€ : IPS panel.
12- BenQ BL2420PT 250€ IPS panel
I am also looking for monitors like the LG i had that are arround 150€ or less, but as i have usually motion sickness and eyestrain i think maybe it could be because a bad monitor or some lack of features (althought it looked good for me).
4- AOC G2460PF 254€
7- HP OMEN 25 254€
My specs:
- Gigabyte GA-X58A-UD3R (DDR3-LGA 1366)
- Intel i7 930
- RAM G.Skill 3x2GB DDR3 1600 (F3 12800 CL 7-8-7-24 1.5v)
- Cooler Master Hyper 212 Plus
- Lancool PC-K60 Dragonlord
- Seasonic X-650 Modular SS-650KM (80 Plus Hybrid-silent)
- Western Digital Caviar Black 1TB FAEX
- ATI Asus 6870
- LG GH24LS50 22X SATA
- Windows 10
- Intel i7 930
- ATI Asus 6870
- Windows 10
