help me to choose mobo for fx 9590
Malen_
11
hello there !
just like the title
i need a suggestion from you 😀
which one better for my fx9590
ASROCK Fatal1ty 990FX Killer vs GIGABYTE GA-990FXA-UD3 R5 ?
or any mobo with the same price as above
any suggest will be appreciated
Well if you don't have the CPU yet I would suggest going for a different cpu, but if you do, the GIGABYTE GA-990FXA-UD3 R5 is a good choice, has an m2 as well as multiple gpu support.
FX9590 is only an AMD's April fool joke went too far or made real.
It is only a heavily factory OCed FX8350. It is hot as hell and consumes power like sh*t.
Despite of the cons, it still does not perform as good as expected.
If you still have not bought it, do not buy it and consider other processors.
Either take the lower FX8350 and OC it yourself or go for Intel path.
If you have that processor already....yeah...GIGABYTE GA-990FXA-UD3 R5 is good.
