help me to choose power supply
Hawkshot
Admirable
Aug 19, 2014
1,772
306
this isn't a very powerful graphics card so yes I will hold it just about but I would recommended getting a new power supply such as corsair 80+ gold at 650W will do you fine
Syahin98
81
how about PSU i mentioned above?
i just need the PSU will hold that card
i will not OC my CPU(NVR it will make my pc demaged if get wrong step)
Hawkshot
Admirable
Aug 19, 2014
1,772
306
Neither really try and look for cool master / corsair as these are some of the best in the PSU business
Syahin98
81
so that 2 cannot be use on that GPU.im on very tight budget.corsair and cool master expensive
Hawkshot
Admirable
Aug 19, 2014
1,772
306
yes they will work but just don't expect to do much over clocking and also don't expect those to last past the manufactures warranty and if you over clock you brake that, so when buying these don't over clock and only expect it to last as long as the warranty is there but if youre that tight on money it will do for now :p
Syahin98
81
so which 1 750 watt or just take the 650watt?
Hawkshot
Admirable
Aug 19, 2014
1,772
306
Corsair RM 650W Fully Modular 80+ Gold Power Supply is a very nice PSU and will see you a long while if you treat her right :)
Syahin98
81
no, i mean that AVF which 1 should i get 750 watt or 650 watt
Corsair too expensive.
Hawkshot
Admirable
Aug 19, 2014
1,772
306
as you are tight on money I would say get the 650W one for now as there is no point spending the extra money as I said ive not heard of that make lasting that long over warranty so save yourself some money go for the 650W :p
Syahin98
81
i can get the 750watt because i can go that far if 650watt not good than i can get 750 just abit spending.
Hawkshot
Admirable
Aug 19, 2014
1,772
306
no for the specs that you told me the 650W will work fine there is enough power in that to keep it up and running no point adding in extra power with no need, you will be spending more money for nothing really, go for the 650W :)
Syahin98
81
ok,thanks
Similar threads
