Help me to choose RIGHT model of gtx 1060 3 gb...
The cheapest one. The differences between any of the cards is a few fps at best, and not something you will ever see since games are not static, the fps bounces all over the place. Or buy the one that matches your color scheme, matches the mobo vendor, looks coolest, has leds or whatever. Just a move from a 1050ti to a 1060-6 is a sizable bump in performance, you'll find it has a lot more leeway on settings, but individual cards don't differ enough unless you go for the extreme high level cards, which might get 5-6fps boost, but again, that's mostly benchmark numbers. Any of the dual/triple fans will have better cooling ability, better OC ability, vrs single fan versions, but that's all.
