***Hi Everyone! Well, this is the 2nd time asking for help to build a new system. Obviously, the previous build of my choice was trashy so i've been collecting some money to build a better one.***
***Basically i'll be using my build to Code, Photo/Video editing, TF2(casual gaming), Unreal Engine and etc.***
***Here's my list of components : http://pcpartpicker.com/list/8XMCLD ***
***And also am planning to connect a single hot swap + a multi I/O thingy.
But the problem is, am not quite sure whether the I/O ports of the case ( 2x(3.0&2.0)+mic/Audio+ power+reset+hd led) would conflict with the front panel multi I/O bay. I kinda want to make use of all the ports in the multi I/O bay as well as the ports which are in the case.***
***Here's the Multi I/O bay : http://www.ebay.com/itm/5-25-USB-3-0-SATA-All-in-1-Front-Panel-Multi-Card-Reader-HUB-PCI-E-PCIE/121405571483?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3D79779146bdea4e2aa3a496dca1cd7ac8%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D161712165575 It has a fancontroller too! ***
***These are the Internall I/O ports supported by the Mobo:
2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) (19-pin)
2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
1 x SATA Express connector: , Compatible with 2 x SATA 6.0 Gb/s ports
1 x M.2 Socket 3
1 x COM port(s) connector(s)
6 x SATA 6Gb/s connector(s)
1 x CPU Fan connector(s) (1 x 4 -pin)
1 x CPU OPT Fan connector(s) (1 x 4 -pin)
4 x Chassis Fan connector(s) (4 x 4 -pin)
1 x S/PDIF out header(s)
1 x Thunderbolt header(s)
1 x 24-pin EATX Power connector(s)
1 x 8-pin ATX 12V Power connector(s)
1 x EZ XMP switch
1 x Front panel audio connector(s) (AAFP)
1 x System panel(s) (Q-Connector)
1 x DRCT header(s)
1 x MemOK! button(s)
1 x Thermal sensor connector(s)
1 x TPU switch(es)
1 x Power-on button(s)
1 x Clear CMOS jumper(s)
1 x 5-pin EXT_FAN(Extension Fan) connector
1 x USB BIOS Flashback Card header
1 x Water Pump header (4-pin)
1 x 14-1 pin TPM connector ***
Any new suggestions will be highly appreciated! Thank you very much =)
1 x M.2 Socket 3
1 x EZ XMP switch
1 x DRCT header(s)
1 x TPU switch(es)
