A AbdeLhadi_1 Reputable Jan 19, 2016 2 0 4,510 Jan 19, 2016 #1 I have This Motherboard MSI H61M-S20 (G3) i Can't Find it in google i want to ask you which Best Gaming config can hundle This Motherboard Please I need to Know soon
Solution cin19 Jan 19, 2016 Sorry. But they have the same chipset H61 http://www.comx-computers.co.za/MS-H61M-S20-MSI-Intel-H61M-S20G3-Socket-1155-3rd-Gen-Buy-p-79211.php and they can support the same 2nd/ 3rd gen lga1155 cpu. As long as the MB has the pcie x16 slot, and if you have the good PSU so you can use the i7 + the high power GPU. Check out the link: PSU requirements for GPU http://www.realhardtechx.com/index_archivos/Page362.htm Get the tier 2 or up for the i7 + powerful GPU http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html
cin19 Titan Mar 14, 2011 15,722 218 112,340 Jan 19, 2016 #2 If you have the budget, get the Ivy Bridge i7-3770 or i5 + gtx980ti + 8GB even 16GB RAM, because the memory is cheap now. Here is the cpu support list http://www.msi.com/product/motherboard/support/H61M-P20-G3.html#support-cpu Upvote 0 Downvote
A AbdeLhadi_1 Reputable Jan 19, 2016 2 0 4,510 Jan 19, 2016 #3 cin 19 my motherboard this H61M-S20 (G3) not H61M-P20 (G3) and want to know it can hundle i7 and gtx Upvote 0 Downvote
cin19 Titan Mar 14, 2011 15,722 218 112,340 Jan 19, 2016 Solution #4 Sorry. But they have the same chipset H61 http://www.comx-computers.co.za/MS-H61M-S20-MSI-Intel-H61M-S20G3-Socket-1155-3rd-Gen-Buy-p-79211.php and they can support the same 2nd/ 3rd gen lga1155 cpu. As long as the MB has the pcie x16 slot, and if you have the good PSU so you can use the i7 + the high power GPU. Check out the link: PSU requirements for GPU http://www.realhardtechx.com/index_archivos/Page362.htm Get the tier 2 or up for the i7 + powerful GPU http://www.tomshardware.co.uk/forum/id-2547993/psu-tier-list.html Upvote 0 Downvote Solution
